tuff wheel uses a specific adapter ( quite pricey now )
and yes the adapter i believe will bolt on your early column,but is noticeably
larger in diameter if that bothers you.
years ago I made one out of 1/4" aluminum. since it was closer to the column compared to the stock adapter, I had to remove and slightly bend the turn signal lever to clear. sorry, no pics
