I thought I would get some input before I get into some more tuning. Fun eh? Its a fresh 340 stock (3.55 4 speed) except '68 4 speed cam and Edelbrock RPM intake. I'm running around 15 deg initial timing with Mancini orange box and distributor. Vacuum is only around 9 inches for some reason but it runs well around town but I would say sluggish with heavy throttle. I did lean it a little with a rod change when it was on the test stand (#13 stage 1 leaner cruise/leaner power). Luckily I have an old Innovate LM1 AFR meter. Right now I get around 14.2 idle, 12.7-13.4 cruise, it will dip to low 12s under light throttle if I'm cruising at a low rpm. If I'm cruising at say 3500 rpm and with light to mid throttle it goes lean 14-15 AFR right away. There is no hesitation or bog symptoms. Where to start? I'm thinking to go a bit leaner cruise/light throttle but I'm not sure what to do about the lean condition. Increase pump shot and see what happens? If you have seen my other post I need a heat insulating carb spacer before I do anymore tuning.
I noticed the AFRs were different...richer at cruise and tip in. I took the car home and measured 12 in vacuum which is an improvement. Perhaps the carb was leaking at the base. Also, the idle rpm stayed stable which is a change. I sprayed the remainder of the throttle body cleaner and then some WD40 around the intake but didn't find anything. I advanced the timing and got around 15 in vacuum. You can't see past 10 deg on the cover so I have no idea what the timing is although I would say more than 15 degrees.
