jlhunsinger
Active Member
Hey guys,
A couple of years back bought an already built 440 Dart. I don't think it has been lightened up much so I estimate 3300 - 3500 lb range.
Parts that I know of:
Indy EZ-1 Aluminum Heads
Indy Dual Plane Intake
727 Trans with 3.55 Rear
10.5:1 Compression
Holley 850 DP, electric fuel pump @ 6.5PSI
Hooker Fenderwell Headers 2.75"
MSD 6AL and Blaster Coil
.509 Purple Cam but do not have any of the cam specs beyond that unfortunately.
I'm told it has a 1900 Stall in it but can not verify for certain.
Overall the car runs great, pulls real hard at WOT but stumbles off the line a quite a bit unless you slowly feed the throttle to it. I'd describe the best results I achieve as going from 0 throttle to 25% to build some momentum (10-15 mph) then feed the remaining 75% to get to WOT. Suggestions have been all over the board on how to fix it so I'm curious what some of you more educated/experienced guys can tell me.
This past weekend I pulled the plugs and noticed they were dark...not oily though. I assumed it was a rich idle condition since I mostly idled or part throttle around the neighborhood the run before to set the pads on the disk brake conversion.
The Holley has a 5.5 Power valve so I hooked up the vacuum gauge to see approx where I'm at. Had all four corner idle screws at 1.5 turns. With the vacuum gauge and making 1/8 turn adjustments to maximize vacuum at idle I ended up around 1 and 1/8th turn which got the idle vacuum hovering around 11-12. Before adjusting it was down around 8-9 so I'm hoping that rich idle adjustment and maybe the PV caused the plugs to be so dark..?
The float levels are set correctly. The jets are 80 in primary and 81 in secondary. I have the 35cc accelerator pump setup with 31 nozzles in both primary and secondary. I was hoping to avoid buying an entire tuning kit to dial it in. I don't have to 100% perfect high performance, I just want more crisp throttle response off the line. Any suggestions on most cost effective way to dial this carb in based on what I'm working with?
10.5:1 Compression
