That's not me. I know most of the team and some of the help (maybe I shouldn't admit that). I'm about 3000 miles away, although did show up at Speedfest and Fling one year, and probably will again.
Key to winning (well the race part, there's other prizes too) is surviving. Its a really long endurance race. Even though the speeds are relatively low, its important conserve tires, brakes, engine; especially in the beginning. Sometimes guys (gals too) get past you because you got forced to a poor line, get slowed down jockeying for position in a mini-race away which drops your lap times, hung up behind a slower or bad driver, or you just don't have the power or speed (need both especially with lower power, keeping momentum is big). That tunnel ram is on a basically stock 318. Everything has to be junk or traded to keep the cost down. If the judges think a team has violated the spirit of the rules, the penalty can be very severe. Lemons races used to always have a demolition crane to dramaticly dispose of a team's vehicle that seemed most deserving! Now how much money would you put in a car that could end up in the crusher? That got the message across. LOL
Take a look in these threads and you'll see who to contact and a little more about the car.
Try PM as Tim's not on FABO that often.
http://www.forabodiesonly.com/mopar/showthread.php?t=256802
http://www.forabodiesonly.com/mopar/showthread.php?t=259617
For help on tuning the carb(s), probably your best help will come from
http://racingfuelsystems.myfunforum.org/
although I'll warn you that there will be a learning curve, but if you have the basics of how a carb works, you'll be fine.
