RichardJ916
Wow that is way to much information....If I wasnt lost before I sure am now....
sounds like the wiring in back left is crisscrossed or someone modified something.
make sure that the sockets are clean, everything has good grounds and no wires have been added/removed.
a brand new full rear wiring harness is about 45 bucks from year one if you want to go that route... it's one of the more reasonably priced harnesses.
the back left sockets are wired wrong / criss crossed / shorted somehow
whoever the bozo is that recommended him pulling his steering column apart first and changing a switch before checking the wires: good job you are killing me
again. new harness from doors back was only $45 bucks
but you can fix what you have. you need to unplug the rear harness connector up by the drivers kick panel that connects the back harness. get a meter. remove the bulbs. check each wire for connectivity / shorts on all 8 of the wires.
your entire rear harness looks somethign like this:
unplug it first before checking each wire, dont leave it plugged in
http://www.crankshaftcoalition.com/wiki/How_do_turn_signals_work?When no turn signal is selected, both brake lamps will receive power when the pedal is pushed. When the left turn signal is selected, the brake lamp for the left side is disabled by the turn signal switch, and the bulb now receives power from the flash unit. At the same time, no change has been made to the right side brake lamp. The result: left lamp flashing, right lamp steady with brakes on. Right lamp is out when brakes are off.
Now, switch to the right side. The reverse becomes true: the right side brake lamp is disabled, and power to the lamp is now provided by the flash unit.
Brakes on or off: the left side remains on (no change to the left side) steady with brake power, and off without it.
This is how the two systems are isolated. This is the most problematic issue for a novice to understand, primarily because nobody ever took the time to explain it to them in any detail.
whoever the bozo is
well those wires are touching together and they shouldn't be. could be where the wires go into the column, or at the connector, etc. you can use a meter and figure out where the front left turn wire is somehow linked into the brake power. it's got to be after the turn signal switch. the wires coming from the column connector frontL/frontR/rearL/rearR are all independent circuits. unplugging the column connector and testing with a meter you will eventually find the culprit, checking with ohm meter you can find out if any of those 4 wires. download that chassis manual from mymopars if you have not. it's on a separate page from the wiring diagrams.
chassis manuals on this page: http://www.mymopar.com/index.php?pid=109
chapter 8 should be electrical, where the diagrams can be found that have CORRECT color codes
Nope, nothing was done to the car, It worked before like normal....
basically when the brakes are applied there should never be power suppied from that circuit to the front.
IF his left front and rear were "tied together" by someone previous owner or whoever, then it could cause this
Might be time to take a big breath, step back, have a coke, and 'rethink.'
That is confirm FOR CERTAIN what is going on
Let's do this:
1.......Leave the rear harness unplugged.
2......Work the brake pedal and confirm that one or both of the front lamps are improperly lighting up with the brakes
3......Unhook the TS switch connector and repeat the test. If anything "up front" lights up front............
then there HAS to be a harness problem between the TS switch connector and the bulkhead, IE in that harness area under the dash.
It would also be helpful with two people. Have the other person watch the front lamp, and with the brake pedal depressed and the problem "showing" wiggle the harness around in that area under the dash.
This is assuming that no one has chopped up the wiring, and added something.
Any evidence this ever had something like a "third brake light" up in the rear window?
^^ Yup ^^ I told you step by step what to do. To repeat..................
1....Hook everything up "normal" and hit the brake pedal. Confirm you still have a problem
2....Disconnect the rear harness in the kick panel and hit the brake pedal. Does the front still light up?
3....Disconnect the TS switch at the column connector and hit the brake. If it STILL lights up, the problem HAS TO BE in that little bit of harness under the dash
Understand WHERE the wiring comes and goes to / from
The quite short wire coming out of the brake light switch comes right up to the connector on the TS switch. Look at the diagram I posted. This is the white wire
With the TS switch and the rear harness disconnected, that wire should go "now where."
Coming OUT of the TS switch connector is the two front left and right bulbs. With the TS switch connected, the turn filaments are connected to NOTHING.
Therefore if they light up, the crossover HAS to be under the dash in the harness.
Let's do this:
