Right..........out.........of.........the...........shop..........manual
http://www.forabodiesonly.com/mopar/showthread.php?t=244981
"Usable" diagrams from MyMopar:
http://www.mymopar.com/index.php?pid=31
http://www.mymopar.com/downloads/1967/67DartA.jpg
http://www.mymopar.com/downloads/1967/67DartB.jpg
1....LIGHT GREEN...left front signal and dash indicator, and one term. of 4x flasher switch
2....RED...power coming to switch from flasher
3....TAN...right front signal and dash indicator, and one terminal of 4x flasher sw
4....BLACK TR...goes to horn button and horn relay
5....ORANGE...lighting for shift quadrant on column
6....DARK GREEN...left rear signal
7....WHITE...cold side of brake light switch and one terminal of 4x flasher
8....BROWN...right rear signal bulb
It is important to understand how the 4x flasher switch works. This is a 4 terminal switch and when off, none of the 4 terminals are connected. When on, all 4 are connected together.
The 4x flasher comes from a fuse, through the flasher, to one terminal of the 4x switch
one terminal goes to left front lamp
one terminal goes to right front lamp
one terminal goes to brake light switch line going into the signal switch.
With the column switch centered, both rear lamps are connected together through the switch so that the brake switch feeds both.
Because on 4x flasher terminal is also hooked there, that means that with the 4x switch on, and the column switch centered, the 4x switch routes hazard flasher power to both rear lights, and the other two terminals route the flasher to both front signals.
This must be wired in separate IE branched/ spliced in as the "hot rod" harnesses don't have provisions for this.
