Turn signals ??
I am not good on a computer, that is why I said what I did. Here is the problem. my back right turn signal and brake light do not work, the tail light does. the car has a aftermarket third brake light. When using the right turn signal is flashes normally on the front but the back does not work, the left side works fine. so the ground is fine because the tail light works so could the problem be the aftermarket light. I replaced the bulb in the tail light and no difference. If acts like the tail light is not even there and that what is confusing me.
