[Found!] U-joint strap
Tracy, I think I have one for 'ya. It's tough to measure exactly...
USA STANDARD GEAR USA41195 U-joint Strap Kit; Includes two straps and four bolts Info
Rear; RWD; Dana Spicer 30 and 44, AMC Model 35 and Chrysler 9.25"; 1310 and 1330 u-joint size
Just look under 1970 chrysler new yorker
A tip from my days in the shop. As long as the holes are round then center to center is the same as the beginning of one hole to the beginning of the other hole, way easier to measure from the edge of a hole to the edge of the second hole than try to guess where the centers are.
That's how I always measure them. You can easily be .020-.030" off trying to eyeball it. Thanks for sharing
USA STANDARD GEAR USA41195 U-joint Strap Kit; Includes two straps and four bolts Info View attachment 1715318385
Thanks Mod. I thought this yoke came off a 68 and looked there but they only showed 7260 and 7290. I didn't realize they used that same size u-joint cap on so many. I think I have a good used one located but if it doesn't work I'll order those. Already put them in the cart for safe keeping
