Can you use the later A body big ball joint in an early A body upper control arm. I see many posts stating there is a difference in the arms, but other than the ball joint issue I'm unable to figure out what it is.
It seems they are the same other than the ball joint socket is possibly bigger?
While looking for the ball joints I've noticed the the early ones cost twice as much as the late ones.
