replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
Ever seen a rod journal damaged from lack of oil? Hint....it doesn't delaminate...Is it possible that lack of oil is what's causing the delamination issue?
I would think that would be a little different situation. But I see your point lolEver seen a rod journal damaged from lack of oil? Hint....it doesn't delaminate...
Oops, I backread a bit and you guys were already talking about cop cars. Pardon me.I wonder how many issues the police/patrol cars have. They may sit and idle for hours at a accident or emergency.
Is that a cast cam or forged? Are the cast cams the issue and not the forged?View attachment 1715538558
As promised. The lifter off of this lobe is fine. I'm not really disagreeing with Tony. If you take enough of these apart, you'll see a lot of scuffing of pushrod and valve tips. You'll also see exactly what he talks about on the lifter bodies. I wonder, with enough low pressure and idling, that heat builds between roller wheel and lobe. Thus, starting to "peel" up the surface. Kinda like taking a torch to mill scale on flat bar. The rest is history. But, as I said earlier, the wheel on this lifter was not damaged. IDK.
Cast.Is that a cast cam or forged? Are the cast cams the issue and not the forged?
Could very easily be.Is it possible that lack of oil is what's causing the delamination issue?
So technically he possibly could be 100 percent correct in his theory lol.Could very easily be.
But the 5.7 Hemi came out in 2003 and Fiat didn't own Chrysler until 2014. Daimler-Benz owned them before and after the 5.7 came out.F.I.A.T. We all know what that stands for.
And Pontiacs. Worn out tooling drilled the cam tunnels at an angle.I remember ..........back in the day.........quite a few flat cams in Chivvies.
Maybe '09....Is there a "magical year" that gets a guy past all the cam/lifter issues?
Just curious, what is the average cost one could expect to pay on a cam/lifter replacement in a shop??? Not asking for your exact quotes, but ball park.... thanksInteresting that he claims that's its NOT a lubricating problem as far as volume, but a problem with the amount of "stiction" of the oil. Very interesting. Of all the 5.7s I have replaced in my shop, ALL of them had delamination, and zero appearance of a lack of oil.
The SRT engines dont have the issue because I believe it was pointed out they have a different camshaft. They still have the same oiling design, the same fifter bore angle ect. Do none of you guys find it odd that a brand new, obviously CNC machined camshaft is only $80 from Chrysler? I am going to say no more in this thread, because no one seems to get it. Its DELAMINATION of a inferior casting.....if yall want to believe otherwise, be my guest...I have a shop to run. Maybe yall can go watch a unemployed guy who sells used parts, and get more technical edu-mucated
Lol...actually, I'm not the least bit upset. I do have lots of experience, I have laid out why this happens, and why the youtube vid is incorrect. I just see no point to continue in this thread when nobody believes my input. Go back and read everything I have posted. But some guy with a internet channel is now some type of technical authority on 5.7 hemis... the same guy that said in the same thread he hasnt ever seen "soft" cams... (AKA early 80s gm 4 cylinders come to mind....) common problem and certainly not "unheard of" Good topic, I've just said all I can! Cheers!You seem awfully upset about this, not sure why.
I also stated the SRT cam was better, but offered an alternate possibility as to the reason for the accelerated failure for "some" non-srt cams. If I missed something and somewhere someone said "all" cams from certain years fail, well then so be it. That still doesn't account for the fact that only one part of the equation is completely constant and that's the design of the block and oiling. The cam/lifter material will NOT (likely) be consistent for a span of years. Something would change.
I don't think anyone is arguing against the cams failing, but other than your visual inspection, you offer no other explanation other than "it's a crappy" casting... I find it hard to believe the Chrysler (Daimler) engineers wouldn't be able to figure that out and have it fixed. I supose I could be wrong, but correcting an alloy for the casting would be a helluva lot cheaper the warranty work. I also find it hard to take anyone serious who doesn't offer up a real explanation and they gets upset when people don't just say "Okie doke...". Clearly enough people aren't satisfied with that mode of thought, not just me...
In the end, I'm not arguing. You build engines it seems for a living, or something... I don't. Best of luck to you. Maybe you're right, maybe not. I suspect this, or your post, won't end the conversation about the cams failing though.
Cheers.
Maybe '09....
What really upsets me the most is when cars were $3000 we didn't have engine problems. I had a 58 Fury with the first year of the b motors, a 350 with 2 four barrels and accumulated over 150,000 miles on it without a problem. These $35,000 to $50,000 trucks with these engines have so many problems. The timing chain was a nightmare because the first few fixes didn't work. Now we hear valve seats dropping, camshafts wearing and roller lifters failing. Unfortunately this is why Detroit has failed us and the Japanese took over the Auto industry. Detroit didn't know Quality until the Japanese showed America they way to build cars. I bought a new 80 Honda Civic and stopped using it when I hit 205,000 miles, because I never had to replace anything, I was afraid everything would go all at once.
Slopar72, I also find Tony to be irritating sometimes. For example, he seems to feel that he needs to post a new youtube video every day. I guess that's how he makes a substantial part of his income. Unfortunately when you feel you've got to upload a video every day, the quality inevitably suffers.
Also, I wonder why the guy doesn't realize he is killing himself with his chain smoking. Once he said he was going to quit, and that it was going to be easy. Apparently he had never tried quitting smoking before*. He quit for about a day, at the most, before he was back to puffing the cancer sticks.
However, Tony does have a lot of experience with Mopars, and he is definitely smarter than I am about them, so I'd better not badmouth him too much. I do learn things from his videos.
*As noted youtube car guy Jonathan Winans (Jonathan W) has remarked, even though he did successfully quit smoking a couple of years ago, he still craves cigarettes every day. Nicotine is incredibly addictive.
