update wiring or service bulletin
stan9341
New Member
does anyone have the fix for slow turn signal operation and lights dimming at idle. Was there a service bulletin or has some one figured this out. I have run 12ga wire direct from the alt to the amp meter and amp meter to the starter relay battery connection but I contuin to get dimming of the lights and slow turn signal operation when you come to a stop sign. any input would be helpful spggwolf@verizon.net
I assume you replaced or deleted those connectors at the factory fusible link and the bulkhead connection block. Check the chassis ground strap at the firewall near blower motor.
