Upper control arm bushings
Tokeland wa
I'm going to order the parts to rebuild my front end on my64 Dart. Question what is the advantage to using off set uca bushings. ???
Thanks Moe
more caster can be dialed into the front suspension...
yup, stock caster setting won't give you much more than 1 degree positive when 2-3 degrees is better for todays tires etc.
YES-- it will have instructions-- also do a search-- I believe someone did a detailed install of them, Lawrence
x2 I vaguely remember someone posting that the pictures in the instructions were wrong....sorry I can't be more helpful.
i believe they get installed opposite of what the directions say.
thanks guys for the information and ABODY for the pics even thouh they are backwards (LOL) going to order parts monday
Moe
Moe
you install them as per the picture i posted. the directions that come with them are not right for what you want i believe..
