Upper Control Arm compatability
vwmoparguy
Riverside, Ca
I'm going junk yard hunting tomorrow for upper control arms for my bbp disc brake conversion on my 65 Dart. I have all the parts except the UCA's. Are there any other cars besides 73-76 A bodies that have UCA's that will work?
I did do a forum search and after a page or so of reading, I simply don't have the time right now to read all the posts.
Thanks
73-76 A body upper is it. Nothing else works unless you want to do some welding.
Make sure the castle nut is around 13/16 area IIRC. Seen some later cars that had small ball joint arms on them, likely swapped from before. Most any 73-76 should have BBJ uppers regardless of front brake set up.
Thanks again. I actually found a set (off the car) not too far from me at what I feel was a reasonable price. The price outweighed me spending time searching and then having to remove from the donor car.
