Used Hooker #5204 are dented, why?
crossy
Active Member
Southern, NJ
I picked these Hooker #5204 up recently, and just wondering why the dents are where they are?- anything I understand the scrapes you can't see on the underside and I have a plan to fix those, but where these dents are has me wondering if I leave them alone? thanx, crossy
The left one is probably steering box clearance and the passenger probably inner fender clearance
Top pic would be for the right T bar clearance, and the bottom pic was starter.
Either that or they are just random dents, but the right side is dented right where the T bar crosses paths with it.
You could put them on and see, then take them off, fix it then have them coated. :D
"IF they need to be there before coating."
Test fit!!!!!!
