[SOLD] Used Mopar Purple cam Shaft P4452761 and lifters
1972DusterPaul
Northville (Southeast) Michigan
$50 + Shipping from 48167 (Northville, Michigan)
People often don't like used cams...but I thought I would offer this up anyways. Comes with the lifters, marked for the proper position for re-assembly.
Approximately 4,000-5,000 miles on the cam. Ran good and sounded tough in my 340. Decided to go with a more agressive cam in my engine rebuild.
SPECS:
Mopar Performance Purple Camshaft Kits
Manufacturer's Part Number:4452761
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,500-5,800
Duration at 050 inch Lift:228 int./231 exh.
Advertised Duration:268 int./272 exh.
Valve Lift with Factory Rocker Arm Ratio:0.450 int./0.455 exh.
Lobe Separation (degrees):110
Thanks FABO for the ad space ,
Paul
I built a 318 with this cam about 5 years ago, it runs great. Has a good amount of torque and power. Good cam IMO
I just purchased the same cam and lifter kit Monday!...I'd return it but since I'm the parts manager I would tell myself no returns on performance parts! :(
Throw some 1.6 rockers on with that and you've got yourself a great setup on a warmed up smallblock. Someone will get a nice cam!
