using spacers on the front spring hanger
345man2
wondering who has ever put spacers in front of the front spring hanger to center the rearend, if you just move one side back say 1/4 inch to center the rear what will it effect, the off tracking tire wear maybe pinion angle or do you have to space both back equally? I have tried shimming them back before cause never needed to, wanting to run a bigger tire and 7/16 clearance to the quarter I aint crazy about, what is your opinions?:D
A 4 wheel alignment will verify if the thrust angle is off.
You may have to shim both sides if it is.
I wont enter into the engineering aspect / why the differential is offset in the first place.
For the mechanical aspect..
More than a 1/4 inch shim will lead to hardware issues. Studs were affixed to the hanger because its impossible to get a end wrench in there with the spring in place.
I used grade 5 nuts, you can get fancy with aluminum or steel, but it works for me.
I took boards that were straight and put them in front of the front wheels, behind the rear wheels and measured both sides till I was blue in the face. I was short some 7/16" on the passenger side; pretty common actually.
what effect would say 1 1/8 or 3/16 spacer on the pass side do to everything? have heard they made them this way because of torque and movementit helped, makes since:blob:
I made a set of plates to lower the front hangars on a E body once. They were 1/4" material and I dropped the top bolts to the bottom holes and had new holes for the bottom bolts in a lower position. They worked well for my application but adjusting side hop was not the issue.
IIRC, there's 1/4 difference built into the front suspension for crowned roads.
Monkey with too much in the back and you'll get it "dog tracking" like a nova.
I agree on thrust angle/4 wheel alignment.
I've used 3/8" solid aluminum block with no issues, space them both the same.
