Jeff Seighman
aka jeffnmo
Bottle Rocket trees Casper, let the fun begin. Wish I knew how to upload the video.
UTG awaits your callout.318's Will Run
Pull your tin-foil hat a little tighter, dude. It's going to be OK.I thought if they were gonna do this as a "publicity stunt" they would have tried to make it look a bit more real. Andy really committed to hyping this up as a "real" grudge race, but it was in fact a setup to help Tony's failing reputation. That ford has allready ran deep into the 6s in the 8th mile, at over 100 mph, but this time it slowed down a full second and 10 mph. LMAO.....you could hear he never even got on it, just made a lazy pass. All a set for gullible followers!
Theres no tin foil hat brother, it was all a setup. I guess you didn't see where the old ford has allready ran in the 6s?Pull your tin-foil hat a little tighter, dude. It's going to be OK.
Yes, the car has no front shocks.looks like he got a little air under the left front tire also.
So what numbers did bottle rocket actually run?
7.69 @91 mph. Sprayed nitrous the entire runSo what numbers did bottle rocket actually run?
Not in my opinion.So a 7.69 out of a 318 in a bigass car ain't even worth an "attaboy"?
Bottle Rocket. That's been its name from the start. It's not like nitrous was a big secret. That car can be duplicated on near bout any budget. Almost no budget. That's worth something.Subtract the supposed "150" shot, that bad *** 318 is making 213 flywheel horsepower. Does that deserve a attaboy? Hell no, that's pathetic
I know, 5 years ago when he started building this thing, he was gonna run 10s in the 1/4 with a nitrous 318 and a overdrive 4speed, with a 8 1/4 rear. That goalpost has been moved quite a ways. Last I checked, a full roller cam setup like in that thing isnt exactly "no budget" nor is building the engine 3 or 4 times allready, custom clutches, and then finally custom built converters ect. He just wants you to THINK it's easy and cheap. It isn'tBottle Rocket. That's been its name from the start. It's not like nitrous was a big secret. That car can be duplicated on near bout any budget. Almost no budget. That's worth something.
7.6's @ 91 is in the 11's in the 1/4.The 1/8 mile et equates to 12.08 in the quarter. So quite bit from the 10 second goal yet. I think the biggest accomplishment is it ran 7.68 made it back on the trailer under its own power without major carnage. 7.68 may be slow for nitrous and 4.88 gears, but I can’t help myself buy to like it. Well, back to my world of scraping wallpaper off the wall the daughters walls for repaint here on chore day, at least someone got to go to the dragstrip this weekend!
