V8 K member
it all about the mounts...What year are you talking about?
i thought I had a picture-- anyhow your car should have the spool type mounts-- if it is a small block the mounting ears/ brackets will be the same height welded to the K, if it is a slant style 1 bracket will be taller than the other.
I do not remember the difference from the pre 73 cars, probably something similar in the height of the mounting pad. Lawrence
