Vacuum Diagram 1972 Dart.
WIFENAMEDCARPOS
Active Member
Harrah
Just got done installing new heater core in duct work. Last owner cut all hoses so I don't know what goes were. Looks like 7 plug connector on back of heater control. One line will feed water valve under hood and other line will go to vacuum pod on fender. Need good diagram what hose goes to what vacuum pod. Thanks
Start with a shop manual. You can download them free over at MyMopar. Some of them "over there came from guys on this board
Thanks, I will look again. The ones I have seen are pretty vague. If I dont have any luck I am going to pull heater control wire up blower motor use vacuum source and bench test controls. Sounds like pain but I am going to get it done. So you have a 67 Dart with 273 ?
