Aloha! I redid my brakes. Put a new MC and Power booster. Changed a few lines, bleed them all. Changed a Wheel cylinder that was not flowing fluid. Brakes work. But when I push the brake pedal the brake pedal stays down. maybe a few inches? (I can't tell if the brakes are still engaged).THIS I know, the Booster is holding it. When I pop the vacuum line the brake pedal goes back to it's resting place.
What am I doing wrong? I measured (a lot of times) the push rod from the booster and the rod isn't dragging or sticking. Vacuum is good...Booster is brand new too. Check valve is made to flow towards the intake.
I may need to bleed the brakes...don't think so...but that wouldn't have to do with the booster holding the pedal down.
The booster vacuum seems good too. I start the car and the brake pedal drops a little indicating the booster is doing its thing.
any guidance? Mahalo!
oops its my 66 barracuda 10" drum stock brakes, dual master cylinder and new distribution valve.
