68fastback
I was told a vacuum secondary on a manual trans will not work. Is this true. I have a 360 with a A-833 four speed trans and a 650 carb with vacuum secondary and wanted to know if that will be a problem. the last owner said he had a vacuum secondary on it and it had very low vacuum and not enough to run the carb efficiently. What are your thoughts?
