Value of RV 440/727
Big Block A body Tech
  1. RussellSullivan
    RussellSullivan FABO Gold Member FABO Gold Member
    291
    365
    Apr 15, 2018
    East Liverpool, OH
    Local Time:
    4:12 AM
    A coworker of mine has for sale a 440 out of his old Winnebago motor home, with a freshly rebuilt 727. As I understand it, the industrial/RV 440s and transmissions had specific parts that are useless in cars. Accessory brackets, different exhaust manifolds, different tail shafts in the transmission, etc.
    What would be a fair price for a running engine with transmission? Considering the cost of parts and effort to swap it into a car. Thanks.
  2. 318willrun
    318willrun Utube channel 318willrun
    17,008
    19068
    Sep 13, 2013
    I'm here
    Local Time:
    3:12 AM
    I would say different parts of the country will bring different prices. But, I think 500.00 - 650.00 for a carb to oil pan RV 440 that runs decent is more than fair. Most of them are low miles. As for the 727, you can swap the tail shaft to make it serviceable, but as to it's value it would be the eye of beholder. For instance, a car guy may give 75 bucks and plan on a tail shaft swap. A guy needing one for his RV may pay 200 if it's proven to be rebuilt.
    • Agree Agree x 5
    • Thanks! Thanks! x 1
    • pauly
      pauly MOPAR or no car! FABO Gold Member
      2,277
      1024
      Nov 1, 2012
      Holton, Michigan
      Local Time:
      3:12 AM
      Best part of that deal is that it’s already pulled and you don’t have to get rid of the motor home carcass!!!!
      • Agree Agree x 11
      • Like Like x 1
      • 318willrun
        17,008
        19068
        Sep 13, 2013
        I'm here
        Local Time:
        3:12 AM
        YES! IF you have to pull it and get rid of the RV carcass, then the value drops considerably, to maybe even free if the scrap yard demands you cut it all up before scrapping.
        • Agree Agree x 1
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          71,820
          47019
          Jun 7, 2010
          Georgia
          Local Time:
          4:12 AM
          And this price range is for a RUNNING engine and transmission. One sittin on the ground or on the shop floor after being pulled is NOT a running engine, but a core.
          • Agree Agree x 5
          • Like Like x 2
          • Disagree Disagree x 1
          • RussellSullivan
            291
            365
            Apr 15, 2018
            East Liverpool, OH
            Local Time:
            4:12 AM
            Thank you guys, as always it's much appreciated.
          • Martin Koiryohann
            Martin Koiryohann Member
            6
            2
            Dec 31, 2019
            washington,mo
            Local Time:
            3:12 AM
            it can be done but most rv 440's r NOT the high horse 440's they have smaller spark plgs ( bigger water passages in the heads for more collong ) as got the 727 trans ? they r truck trans u can hake it work if u have the right trany cross member & drive shaft length
          • Brooks James
            Brooks James Dustoff
            854
            451
            Dec 12, 2020
            Fruitland Park Fl
            Local Time:
            4:12 AM
            If I remember correctly the small plug heads were not too good for performance applications
            I’m pretty sure there are special gaskets to run regular heads
          • S.Rodney
            S.Rodney "Hang 10" owner
            52
            20
            Dec 17, 2016
            Quebec City, Canada
            Local Time:
            4:12 AM
            Don't know how "useless" they really are for Cars... but here's a famous project car with said motorhome 440...
            • Agree Agree x 1
            • RustyRatRod
              71,820
              47019
              Jun 7, 2010
              Georgia
              Local Time:
              4:12 AM
              I see @Minnesota Muscle disagreed with this statement. So tell me, does that mean you'll pay premium price for an engine sitting on the floor that does not run?
            • Dartnut
              Dartnut Don't hate me because i'm beautiful
              11,468
              4185
              Apr 19, 2007
              Southern Alberta
              Local Time:
              2:12 AM
              I agree 100% as long as it was stored inside and out of the elements.
              How long ago was it pulled?
              Was there anything put in the cylinders to keep the engine from seizing?
              If it wasn't taken care of in this way, it would be deemed as a core to me and worth $200 to $300 with the tranny.
              After this is all put into perspective, the R.V. engines (depending on the year) are considered low compression engines that might have the different heads with smaller spark plugs (for cooling) and valve rotators which isn't bad overall.
              If it was proven good, I think that your post is right on the money.
              • Agree Agree x 1
              • Minnesota Muscle
                Minnesota Muscle Active Member
                31
                19
                Aug 17, 2020
                Mid-Minnesota
                Local Time:
                3:12 AM
                Stop being a sensitive Nancy because someone disagreed with you on the internet. It's all relative. In my area a decent looking non-running 440 on a pallet that turns over is worth $800 all day long of not more. A running 440 is $1000-1200. I bought four 440's and two 413's last year, and some of them I had to fight for as they sell quick.
              • Dave_J
                Dave_J Well-Known Member
                85
                97
                Nov 27, 2019
                Auburn, WA
                Local Time:
                1:12 AM
                Had a friend inherited 2 Class A Winne's with 440/727's. The Scrap yard would not let him even bring the barges on their parking lot with the 'Black Water' tanks still in the frame. Its like $8,000 for them to scrap one that has the tanks under. Hazardous Waste fees.
                And with all the wood inside, the scrap value is not much so my friend took them apart and got a lot for the aluminum, chassis and running gear. No one wanted the 440's on Craigslist.
              • Oldiron440
                Oldiron440 Well-Known Member
                604
                782
                Jan 12, 2019
                North central Iowa
                Local Time:
                3:12 AM
                I was thinking $500 for the pile.
                You can't use the transmission but for parts.
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                48,309
                16341
                Oct 14, 2010
                Idaho
                Local Time:
                1:12 AM
                Why not?
              • Oldiron440
                604
                782
                Jan 12, 2019
                North central Iowa
                Local Time:
                3:12 AM
                Does the transmission have the the drum park brake at the end of the tailshaft?
              • RussellSullivan
                291
                365
                Apr 15, 2018
                East Liverpool, OH
                Local Time:
                4:12 AM
                I haven't been over to look at it. I can find out. I'm not gonna buy it regardless. After some thought, there are other things that need attention first.
                • Like Like x 1
                • Minnesota Muscle
                  31
                  19
                  Aug 17, 2020
                  Mid-Minnesota
                  Local Time:
                  3:12 AM
                  Craziness. Local trend fluctuations are always interesting. I need one more 440 and two 727's with passenger car tailshafts if he still has them, lol.
                • fish stink
                  fish stink Well-Known Member
                  93
                  57
                  Mar 17, 2018
                  fort st john b.c. Canada
                  Local Time:
                  1:12 AM
                  i paid 500.00 canadian for a very low millage 440 and funky tail shaft transmission. when i get a blown up 727 then i will pirate the tailshaft and then it will be a normal trans again but no need for a rebuild. gutted to engine (1977) and have a very nice engine core to build my beer can headed 440 source screamer for my 69 Cuda. motorhome had a kitchen fire so the front where the engine was is perfect and i was not stuck with the dead burnt whale. got the same deal for a 454 last gen all 4 main cap bolts bottom end with a one piece rear main seal. can one say nice blower motor build base? Dodge will need a girly girdle to survive my right foot hay watch this play time.
                • 67Dart273
                  48,309
                  16341
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  1:12 AM
                  Big BIG problem with motor homes around here is
                  1....People want you to take the whole thing with you
                  2....They actually think they are worth something
                  By the time you add up all the nonsense....and possibly money out of pocket......to get rid of a motor home hulk and by that I mean AFTER you have cut it up into little bitty pieces.....if they GAVE you the thing with a running engine/ trans it might not be worth the trouble AND MONEY
                • Oldiron440
                  604
                  782
                  Jan 12, 2019
                  North central Iowa
                  Local Time:
                  3:12 AM
                  Isn't the output shaft different on the RV transmission, flanged instead of a slip yoke?
                  In order to change the output shaft the trans needs complete disassembly.
                  • Agree Agree x 2
                  • 67Dart273
                    48,309
                    16341
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    1:12 AM
                    Pretty sure that is only true of the big "class a" stuff. The smaller "van nose" types are pretty much slip yoke
                    Other thing you need to watch out for in the big stuff is the -3 engines which can be much different, esp. 413/426 with the oddball heads/ intake/ exhaust. What you essentially have with them is a block, crank, and "I guess" rods
                    • Like Like x 1
                    • RussellSullivan
                      291
                      365
                      Apr 15, 2018
                      East Liverpool, OH
                      Local Time:
                      4:12 AM
                      Yeah, after considering all the trouble that would come with it, I decided against it. I had no idea the dissimilarity between the RV motors and "regular" motors. Add to that the fact that I'm trying to downsize anyway, it didn't make sense to go for it.
                    • barbee6043
                      barbee6043 barbee 6043 FABO Gold Member
                      14,049
                      6789
                      Jul 20, 2008
                      Shepherd, Texas ( SE Tx)
                      Local Time:
                      3:12 AM
                      I have paid $500 for a good running ones 10 years agao, and now I see some can be had here as cores for $500. Time marches on. Tx. is higher than Mo. too. Less its running, it is a core!... price depends on location and how easy the buyer is to get $$$$ out of! That why gas is higher in Ca!!!
                      • Like Like x 1
