Valve Clearance
Big Block A body Tech
  1. Aaron Majcan
    Aaron Majcan FABO Gold Member FABO Gold Member
    23
    17
    Feb 26, 2018
    Alberta, Canada
    Local Time:
    2:38 AM
    I have this Lunati cam: Lunati Voodoo Cam and Lifter Kits 10230704LK
    I'm hoping someone much smarter than me can help me with valve clearance calculations based on its lift and duration.
    Its for a 383 0.040" over with flat top pistons sitting 0.015" down hole at TDC. I don't know enough about cam rotation to know if I will have enough clearance. I don't have the pistons yet so before I buy them, I need to know if they'll work first. The heads are Edelbrock E-Street 5090.
  2. fishmens67
    fishmens67 Well-Known Member
    5,577
    2391
    Nov 10, 2012
    idaho
    Local Time:
    3:38 AM
    flat top with no reliefs and if it indeed is .015 in the hole, I think clearance will be an issue.
    I'm thinking the pistons will be much further in the hole without decking, like .080 or so.
  3. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    51,153
    18193
    Jun 7, 2010
    Georgia
    Local Time:
    4:38 AM
    That cam doesn't have enough duration to run the valves into the pistons at zero deck.
    • Agree Agree x 2
    • fishmens67
      5,577
      2391
      Nov 10, 2012
      idaho
      Local Time:
      3:38 AM
      I wouldn't gamble. measure , larger valves will make it close , no room for error.
    • '63GT
      '63GT Well-Known Member
      507
      404
      Jun 9, 2018
      Turlock, CA.
      Local Time:
      1:38 AM
      Mathematically, your intake valve will be approximately .116 (edited) off the seat at TDC. IF you have the cam advanced 4°. give or take.. less by .010 if straight up.
      If you know how much the intake valve is above the cyl heads deck surface, you can subtract that amount, plus gasket thickness, deck height (piston down = .015) and valve relief, if any.
      You're gonna have to get some measurements off the head..
      • Like Like x 1
      • Aaron Majcan
        23
        17
        Feb 26, 2018
        Alberta, Canada
        Local Time:
        2:38 AM
        So if I place my head face down on a table and measure valve travel until it touches the table, add crushed head gasket thickness and subtract .116", that should give me any clearance I have? (if any)
      • yellow rose
        yellow rose Doctor of Thinkology.
        16,601
        12933
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        1:38 AM
        Why don't you just do a mock up and check your P/V with clay? Then you will know what you have.
        • Agree Agree x 2
        • Aaron Majcan
          23
          17
          Feb 26, 2018
          Alberta, Canada
          Local Time:
          2:38 AM
          Because I don't have the pistons yet. I don't want to buy them only to have them not work out and be stuck with pistons I can't use.
        • JBurch
          JBurch Well-Known Member
          1,693
          811
          Oct 17, 2009
          Owego, NY
          Local Time:
          4:38 AM
          As YR stated, why not mock up your assembly and then find out IF you hit or NOT, and WHAT your clearance is, if any.......it's good to ask questions here, but there is no substitute for checking and measuring on your own........some one 1000 miles away does not have a crystal ball clear enough to tell you "YUP", "Nope" and be dead certain...............it's not that hard to do
          • Agree Agree x 2
          • yellow rose
            16,601
            12933
            Jun 19, 2015
            Local Time:
            1:38 AM
            You don't know anyone that can notch a piston? Unless you are running a fairly long camshaft you probably won't have issues. It still needs to be checked.
            Buy the correct piston to get the compression ratio and deck height. Then check P/V and if you have to notch the Pistons so be it. It ain't that hard to do.
          • JBurch
            1,693
            811
            Oct 17, 2009
            Owego, NY
            Local Time:
            4:38 AM
            Here's a question, or 2, or 3...........for the sake of discussion, what are your piston choices IF the valves hit, what would you do IF you only had .010inch clearance with the valve open........loose rule of thumb is .080 intake, .100 exhaust, how would that impact your build..........are you gonna push pistons down in the hole to gain P/V clearance at the sake of loosing compression..........if valves are close, or hit, you can always have eyebrows cut for clearance......done all the time
          • '63GT
            507
            404
            Jun 9, 2018
            Turlock, CA.
            Local Time:
            1:38 AM
            The clearest cut way, is to do what YellowRose said. It's empirical, no math required, just a little set-up. But I see you don't have all your parts yet...
            You subtract from .116
            Hypothetical example: subtract these measurements. Valve to deck .080"
            Steel shim head gasket .018
            Piston down hole .015
            =.113 or -.003 P/V
            So, IF your measurements are like the hypothetical examples I used, you'll have a problem.
            BUT, IF you order these pistons (a bargin at $389, OR a set like them) all your worries will disappear. KB162-40
            These have .264" worth of valve relief Int/Exh and you'll have enough clearance for more cam than you'll want. AND, you can take RustyRatRod's 2 cents to the bank !
            • Agree Agree x 1
            • 67Dart273
              67Dart273 Well-Known Member
              39,501
              7146
              Oct 14, 2010
              Idaho
              Local Time:
              1:38 AM
              Well measure it with what you have, and then reference that figure to the proposed pistons. Laying the heads on a table doesn't do it because minimum clearance does not happen at TDC. It happens as the pistons move, and the valves open, and of course varies with cam "degreeing"
            • Aaron Majcan
              23
              17
              Feb 26, 2018
              Alberta, Canada
              Local Time:
              2:38 AM
              The idea here was to get member thoughts on clearances based on the duration of the cam because mathematically, I'm unsure of the calculations. Yes I'm sure someone could notch pistons for me if I needed to but I'd rather not add unnecessary machining costs if I can just get the right pistons the first time.
              Mathematically, it sounds like my duration is not long enough to be a real concern so I can now confidently buy the pistons in mind and check the clearances with clay once mocked up. Thanks folks.
            • Aaron Majcan
              23
              17
              Feb 26, 2018
              Alberta, Canada
              Local Time:
              2:38 AM
              What's the compression height of these pistons? I need 1.92"
            • JBurch
              1,693
              811
              Oct 17, 2009
              Owego, NY
              Local Time:
              4:38 AM
              They are 1.908
            • '63GT
              507
              404
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              1:38 AM
              I've got a headache now...
              • Agree Agree x 1
              • Aaron Majcan
                23
                17
                Feb 26, 2018
                Alberta, Canada
                Local Time:
                2:38 AM
                I didnt intend to confuse anyone. All sorted now though, thanks everyone.
                • Like Like x 1
                • fishmens67
                  5,577
                  2391
                  Nov 10, 2012
                  idaho
                  Local Time:
                  3:38 AM
                  #1 why would you choose a cam before the short block is together. you want as close to zero deck as you can get with the 383.
                • Aaron Majcan
                  23
                  17
                  Feb 26, 2018
                  Alberta, Canada
                  Local Time:
                  2:38 AM
                  I had 1.848" compression height pistons in it already that came with my block when I bought it and it put me 0.090"down hole at TDC when installed them. I found 1.92" flat tops that will get me much closer to zero deck. I didnt think to measure my piston clearance before I pulled them out. Rookie mistake.
                • '63GT
                  507
                  404
                  Jun 9, 2018
                  Turlock, CA.
                  Local Time:
                  1:38 AM
                  No disrespect, but most of us here have found it necessary to 'deck' a block in order to achieve the desired deck height. ..just the way it goes. In fact, you'll end up with a much better product when finished, cause in many cases, the block is out of square or some other crazy anomaly. As well as having a better surface for head gasket bite.
                  BUT, this is only done when you know what pistons, rods, and crank you will be using.
                  • Agree Agree x 1
                  • 440 Mike
                    440 Mike Well-Known Member
                    111
                    32
                    Jul 18, 2016
                    Minnesota
                    Local Time:
                    3:38 AM
                    If I have this right, you already have your block rough bored .040? Why not buy one cast .040 piston with less compression distance than you want to run and mock it up, see what you have for valve clearance and add compression height to it mathematically. Check for deck squareness at the same time.
                    I'm told that 383's are a little more critical when it comes to PV clearance because of the shorter stroke/longer dwell time of the piston.
