4spdragtop
Hi all, anyone know what these would have come on? I'm thinking 70 up? But not sure 340? Has tall loom for 4bl carb.
Thanks
Steve
Thanks
Steve
1970
70 and 71 most people say are the same but there is a slight difference on the loom is a quarter inch to 3/8 in difference in placement....I've had both
Believe it or not those are the same valve covers that came on a 70 AAR Cuda some say they were a little different but they weren't
Nice score Steve.
There's a pair on eBay for $750 ....they are very desirable covers...many $45k cars don't even have them on them
I have a pair of vintage Cal Custom valve covers that I'm using. They're thick aluminum so no flex or worn out flange holes. It's old school look and function. If you decide to go another route, this is a good option. Definitely stay away from the cheap Chinese garbage.
I believe the only difference between the T/A covers and the rest of the 340 covers is the stand alone wire loom is located in a slightly different location. With the larger six pack air breather more space was required so slightly different location. Small modification but otherwise yes the same.Believe it or not those are the same valve covers that came on a 70 AAR Cuda some say they were a little different but they weren't
