Bigdummy
Not a Nova
Trick flow heads . 016 intake and .018 exhaust sout I go up .002 I forgot it's been a while to adjust them?
If those lash adjustments are recommended @ .016/.018 hot........then with aluminum heads and an iron block I would set the lash cold at .010" intake and .012" exhaust.Trick flow heads . 016 intake and .018 exhaust sout I go up .002 I forgot it's been a while to adjust them?
Excellent info from a great source! Does the same hold true with Eddy heads? I have a Comp street solid roller in my 470" It wants .016 and .018 hot. I hate checking them hot so can I also do .010 and .012 cold. I know every engine is different but.....??If those lash adjustments are recommended @ .016/.018 hot........then with aluminum heads and an iron block I would set the lash cold at .010" intake and .012" exhaust.
Agree 100%! Was just curious if the Eddy heads react the same as Trickflows.I would do EXACTLY what IQ52 tells you to do.
In my experience yes. Aluminum Edlebrock, Indy, Trick Flow, 440 Source, Speed Master. 10-12 years ago (maybe more) I found out about it reading a Chevy engine build article using Edelbrock Aluminum heads. Then the Edelbrock Tech Line told me their heads wouldn't do that when I was purposely testing and measuring the valve lash on a set of Edelbrock 440 RPM heads. From cold to hot I was seeing a +.005"-.006" change in lash. Never consulted Edelbrock's Tech Line after that.Excellent info from a great source! Does the same hold true with Eddy heads? I have a Comp street solid roller in my 470" It wants .016 and .018 hot. I hate checking them hot so can I also do .010 and .012 cold. I know every engine is different but.....??
Yep, that's the way you do it.Have your tools ready. Get the engine to operating temp & then switch off. Quickly remove a valve cover & find a loose rocker. Measure the lash & record it. Come back in the morning when the engine is cold & re-measure. You now have your hot-cold difference.
And by-the-by, with aluminum block and aluminum heads I tighten the cold lash .010"-.012" from the hot lash setting. Gets a little dicey with a very tight lash cam.
To me, 0.006" is a lot to take out of the lash for alum heads. My experience has been about 0.003".
However, this is so easy to check, it beats me why more people do not do this simple test that will give an accurate number for their combo.
