darndart
I’ve got a 1985 360 that I pulled out of a wrecked Ramcharger many years ago. It appears to have been rebuilt at some point, it has brass freeze plugs, double row, timing chain, and is extremely clean inside. The heads are the older 915 J castings. But it appears that when the heads were rebuilt, newer style valves were used that originally had came with rotators on the exhaust. It has standard retainers on it now, but you can see in the picture that the valve spring height are much shorter on the exhaust valves than they are on the intake valves. I am planning on adding a summit cam and the comp 901–16 Springs. My question is, do they make an offset retainer or keepers to get the valve spring height at the proper level with the rotator style exhaust valves?
