71swing
Im pondering the idea of going with a bigger cam for my 408. Comp cams recommened their 20-228-4 cam.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=632&sb=2
It states below in the link that this cam is not to be used with stock springs. I have eddlebrock rpm heads that come with springs good to .575 lift. will these springs do the job or should I really make the switch to a double spring?
If I need to buy new springs?
I understand the the inner spring on the double springs needs to be removed for the cam break in. If this is the case can I install the cam and break it in under my current springs then replace them with double springs or should I do it with the new springs outer spring only?
