Jlcaptain24
440 w/factory 452 rebuilt heads....with factory springs. My thoughts was to use the softer factory spring for cam break in (hydraulic flat tappet) then swap springs.
I'm running summit 6401 Cam
Intake Duration at 050 inch Lift:224
Exhaust Duration at 050 inch Lift:234
Duration at 050 inch Lift:224 int./234 exh.
Advertised Intake Duration:298
Advertised Exhaust Duration:303
Advertised Duration:298 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.488 in.
Valve Lift with Factory Rocker Arm Ratio:0.466 int./0.488 exh.
Lobe Separation (degrees):114
The closer I get to firing the engine off, the more nervous I get about stuff. Does what I'm doing make sense?? Or is coil bind going to be an issue??
Regards,
Jason
Regards,
Jason
