Im currently running a Hughes Hydraulic roller cam (242/246 @ 0.050") with Edelbrock LA heads with Ferrea 2.055 Intake valves that are a bit on the heavy side, with the Hughes 1129 springs (145# closed / 358# open). I'm also running the Hughes 1.6 shaft rockers so everything in my valve train is heavy. I'm currently getting valve float at about 5900 rpm. I'm looking for spring recommendations hopefully something available with a titanium retainers that will work as a drop in on the heads that I can swap in the car.
Thanks in advance for the help
