1971 225c.i. Slant/6 40-thousand miles, Automatic
Typical common slant/6 problem...fuel line percolation, vapor lock, hard re-starting, etc.
It's a total bummer sitting 30-45 minutes to re-start after warm shut-off.
Have done the "extended tip plug mod", added a Pertronix II module w/a MSD-6. No metal ring-gaskets on plugs. Fresh carb.
Have seen the fuel line re-routed from fuel pump over the valve cover & on to the carb, in order to avoid the exhaust manifold heat.
The same fellow used A/C line insulation as a cover for the re-routed fuel hose.
QUESTIONS:
What cured your vapor lock, fuel perc, & hard re-starts on your slant/6?
Any other "mods" to do? One fellow said he improved his engine's re-start probs with a valve lash re-set. Another said the stock location fuel filter
contributed to the prob, acting as a little coffee pot.
------------------Any pics of your cures?------------------
Thank you tremendously, as this beautiful car, wonderful in all other respects, simply can not be driven often or reliably as-is.
QUESTIONS:
