Can any one help me ..I have a fresh 318 bored 40 over Keith Black piston (flat top) Mopar Perfomance purple cam and lifters adv duration 280/280 dur@238/238 lift 474/474 and 203 cast iron heads Not Milled fresh vavle job comp cam valve spring od 1.460 id1.060 seat load 124 lbs @1,800" open load 239lbs @1.250" coil bind 1.95"rated 308s/n new stock push rods and used stock rocker arms and shafts. Fel-Pro head gaskets. Less than 10 hours on engine and it pushed the push rod though #1 Exh rocker arm ball seat and bent #1 intake push rod and did same thing on # 7 cylinder all other cylinder seam to be fine carry about 50 psi of oil pressure all rocker arm are getting oiled ,No its not been over reved .. Haven't even driven car yet still in the process of restoring car ,Any help would be greatly appreciated :banghead:
