Viper21700
Ok guys, at the request from another member, Im starting yet another electrical thread dealing with voltage drop. I hope to document the steps with the assistance of other members so people can get a better understanding, as well as solve the issue Im having.
Background- 1966 Plymouth Barracuda, LA360 V8, Isolated field alternator installed already using single field voltage regulator (second field jumpered to ground). This system works ok- but provides very little charge at low RPM. Will be upgrading ignition system to electronic ignition in near future, so the time has come to upgrade the VR as well.
Problem- Installed mid 70's two wire voltage regulator and wiring harness, voltage spikes to 18v when engine RPM's increased.
Troubleshooting steps completed-
Utilized dremel tool to clean grounding points to bright shiny bare steel, cleaned all bolts and grounding strap ends as well.
Installed second ground next to battery directly off of Negative terminal post.
Check for voltage drop from + terminal on battery to starter relay stud- .028V (well within suggested specifications according to Dart273)
Checked for voltage drop from + terminal to positive ignition point on ballast resistor- 1.0-1.1V drop. Attempted this with all accessories turned off, but ignition on (engine off of course)
So where should I go from here? Ive narrowed down one of my issues to the ignition circuit, but where do I start looking on this circuit? Ive heard people say just run the alternation VR off of a relay, but I consider this a Band-Aid solution at best. It might cure one issue, but Id rather complete the job correctly, and learn the evil intricate nature of the magic smoke devil known as 40+ years of wiring disaster.
Thanks guys- lets get this party started.
