Never said you don't know anything rumble. Nor did I intend to have it seem so.
As you say to reference the catalog here's some truth for those interested:
Lunati does not reference anything Mopar specific. Here are quotes from their catalog:
Pg 144 - Chevy hydraulic flat tappet cams:
" Voodoo: Lunati's Voodoo series of camshafts deliver more area under the curve than any other series of camshafts. This means more throttle response, quicker acceleration, more vacuum and better efficiency. These factors, combined with maximum horsepower and torque, make Voodoo camshafts the perfect choice for a wide range of high performance applications."
Pg 20 - Chrysler LA small block flat tappet cams:
"Voodoo: Lunati's Voodoo series of camshafts deliver more area under the curve than any other series of camshafts. This means more throttle response, quicker acceleration, more vacuum and better efficiency. These factors, combined with maximum horsepower and torque, make Voodoo camshafts the perfect choice for a wide range of high performance applications.
In comparing the duration @ .050 of the SBC (#10120703) to a similar version in LA Mopar (10200703) cam, the Chevy cam has 1° more on the intake, 1° less on exhaust. There is a slight bit more lift on the Mopar - which in turn means it has a little more advertised duration than the SBC version. But that is a very, very minute difference and in a part of the lobe that has less of an effect than lower lifts where rate of lift is crucial.
The VooDoo line puts more area under the curve as compared to other shelf grind profiles. But it does not use rates of lift that are mopar specific or risky with an .842 lifter.
I'll continue to say cam lobes have no clue what engine they're in, and no shelf camshaft for a Mopar (possibly excluding some Hughes grinds) will push the rate-of-lift envelope far enough to be unsafe with a smaller lifter. Custom lobes are another story - but nobody warrantees custom grinds so they don't care if it fails.
That's the truth as indicated by looking at the published lobe design info - not listening to the sales people or literature. Sorry for any perceived attack.
