Pushing it hard, yes. I have spoken to one other guy that has done it similar to what I want to do. 604 HP on stock stroke. Just very big cam, good ported heads and a lot of compressionTo put it in perspective.....
At 365”(+.030”, stock stroke)..... 600hp is just over 1.64hp/ci.
Which is like a.......
-521hp 318
-557hp 340
-628hp 383
-656hp 400
-731hp 446
-808hp 493
-828hp 505
-885hp 540
-938hp 572
Nothing I have built myself has quite reached 1.64hp/ci.
However we have had a few on the dyno that good, N/A....... but it doesn’t happen real often.
-521hp 318
-557hp 340
-628hp 383
-656hp 400
-731hp 446
-808hp 493
-828hp 505
-885hp 540
-938hp 572
"9.96 @ 133 W2 340 Cubic InchI think it can be done? my 340 has been 9.90 at 133.4 mph. 2800 lbs. must be close to the 550 hp
What would you do?He better hope those heads have good rocker arms and all the gear to go with them.
What CR are you pushing in your 340?I’m still running ductile iron rockers and have had zero issues. Nothing fancy but gets the job done.
nitrous or anything or just straight-up motor in a super-light car?Compression is 11.4
RatBastid, My launch rpm is set at 5000 and I shift at 6400. 416 cubes with 10.4 compression, IndyBrock heads, Bullet solid roller, Victor Jr intake, 1 7/8 headers, full 3 inch exhaust, and a Jerico DR4. Just a fun street beater that runs high 10's not real quick but fun to drive.
N/A and 2800 lbsnitrous or anything or just straight-up motor in a super-light car?
There is absolutely nothing wrong with those rockers. In fact, if you could have had them in a 1.6 ratio I would have used them. They are way better than a lot of the other stuff out there.
