I have not seen a specific shaft for the W2 Econo heads available these days. Do you use a quality stock shaft and drill out the mounting holes to 3/8 from 5/16? W2 Econo shaft pedestals on the heads require a shaft that is drilled on center so the pricey W2 race shafts are not an option.
