Ha ha ha, well, that is the Est. of it with what is a typical Fel-Pro head gasket.
Fel-Pro has a .054 head gasket as well. It'll give you a 10.10-1 ratio, 70 cc head chamber, 10.69 w/a 65 cc head.
Also, I corrected the ratio above in the first post since I goofed with a 4.00 inch bore to calc when you said it was .020 overbore. There is a slight rise in ratio that has been corrected in the first post. The all ratio's above are correct for a .020 overbore on the 360, stock stroke.
Install a slug and rod to see where it will sit in the block. If your wrist pin is a floater, the slugs can still be sold as new. They were just test fitted.
