[FOR SALE] W2 heads and intake
roachmech
Active Member
California
Rating - 0%
0   0   0
Nos Mopar performance W2 cylinder heads
Full race porting
2.08 intake valves
Holly Strip Dominator intake manifold race ported to match heads.
Race porting done by Performance Racing engines Mesquite Texas.
Thea’s are not for street use.
They are for a. Race car.
$5000 obo
Possible Trade for edelbrock mopar 360 heads plus cash
Los Osos Ca 93402
I guess you could use them on the street.
I bought them on a estate auction and dont know the flow numbers.
they look way to radical for my daily driver
Looks like LA exhaust pattern, early W2 had only stock pattern, later versions have both LA and W2. Got a picture of the ends of the heads? Do they have freeze plugs?
Thank you I just couldn't understand why a more efficient head would be to radical for the street...
I'm not that good with this stuff but I would have thought the cam used with that would be all the difference...
You would be correct. They’ll be fine on the street.
Those look to be very early castings, 1978 by the numbers, standard exhaust pattern, and lack of “W2” cast below the spark plug holes, and lack of reinforcement ribs around the head bolt bosses. Cool find, good luck with the sale.
Mopar performance W2 Race cylinder heads
Open Chamber
Early casting with single exhaust bolt pattern.
Ported intake and exhaust
Intake runner 195cc
exhaust runner 70cc
Combustion chamber 66cc
.370 valve stem
2.05” installed spring height
2.08” exhaust valve
1.6” intake valve
Stainless valves
Double springs plus damper
180 lbs seat pressure
680 lbs @ 700 lift
Coil bind @ 800 lift
Titanium retainers
10 degree locks
Holly Strip Dominator intake manifold ported to match heads.
$3000
I put them on eBay too
