It is really nice to see the interest in these overlooked OD 4-speeds. It was just great in my '69 Dart as I said earlier. The 360 I had in it had fully ported and polished X heads with big stainless valves, a hot Hughes solid lifter cam and kit, Crane roller rockers (1.6 intakes), ported RPM Airgap intake, 650 double pumper, Mopar super gold ECU and a custom curved stock distributor. It had Hedman headers, 10.5 Hayes B&B clutch, Hurst Super Shifter II with reverse lockout, narrowed 8-3/4 rear with 3.55 power lock and 28" tall tires 10" of width. The motor revved like it thought it was a 340! I shifted at 6,000 and it wasn't out of beans either. Here is where I found that OD trans a real blessing: On the street, the fun is usually from stop light to stoplight, right? That deep 3.07 first gear ratio lets you jump out of the hole like crazy. I had no trouble leaving 5.0 mustangs and 350 Camaros behind. The drop to second gear is not so noticeable under a power shift. Nobody ever beat me and that's the truth. When you hit third (1-to-1), you really get the rpm drop but by then yo gotta be on the breaks anyway! The next thing is hitting the highway...it is so Interstate friendly! Smoothe and quiet and saving gas. I wouldn't recommend one of these ODs for drag strip use because of the ratio spread only. If they were so easy to bust, the one in that Dart would have been busted long ago! It never leaked gear lube-ever. You can tell when you have a cluster shaft problem because the case will leak. To anybody interested, the 833 ODs in pickups and vans use a long cast iron tail shaft with a shifter mount in the B-body position. I saw one that had an E-body position as well but the holes were not drilled. The A and F-body cases are the nice short ones and bolt right into any stick Duster, Valiant, Barracuda, Dart or Demon. You appreciate that aluminum case if you are on your back in the driveway changing them out! All of the gears are the same and interchangeable. The front shift ear goes on upside down so that the shift patern remains a standard H. If at all possible, get the ears and shift linkage with the trans you buy. The later model Aspen/Volare shifters were neat too. They clear a bench seat and have a built in reverse lockout feature; you push down on the handle to engage reverse. Rock on with the ODs! Remember: real men drive pedal cars! LOL!
Pat
