Water Pump _Timng Cover Bolts?
340six
King Of Bling
New Orleans
70 up small block A 318/340/360 lengths.
I have 3 or 4 sets of high strength stainless i sanded and polished but are in attic. Neurosurgery did me in and am still recovering. And mine are picked up to where I can not get to them so figured I would ask.
ARP tech says that they do not sell a kit would need to sell separate products. But does not know sizes
Thanks
What accessories are you running
That is a really good question... Something the OP should do regardless is use a piece of wire coat hanger, or chopstick or the like and once all the accessory drives are in place insert it in each hole one by one to determine the maximum length the bolt can be.
Some of the holes are blind, some go into the water jacket and can crack the cyl wall if the bolt is too long and others go into the oil valley above the water pump.
Really good how too, Thanks to KrazyKuda!
You have to scroll way down to get to the good stuff
Part 11
How to Rebuild a Small Block Part 14: Preparing the Timing Chain Cover
Part 12
How to Rebuild a Small Block Part 15: Installing the Timing Chain Cover and Water Pump
