[WANTED] water pump and manifold
winstoninwisc
Taint easy livin free,season ticket ona 1wayride
sun prairie wi.
I neeed the water 2 threaded hose connecters necks for a 340 water pump and 2 necks for the manifold and j hose if you have a good 1 ,and a thermostat housing if any body has a manifold and parts laying around . thermostat housing can be a straight neck if some 1 has these parts they would like to get rid of quick.
thanx all pm me asap water pump hose fittings needed
if they are the threaded type heater hoses 2 for the heater hoses 2 with the j hose and a non crome thermostat housing
neeed the screw in type of hose fittings for smallblock to heater hoses , non chrome thermosat housing ,and the 2 fittings for the small j hose to manifold , and the j hose if no weathering asap for some 1 with an old motor laying around , no rusted junk 4 fittings 1 j hose and a themostat
any 1 have a set pm me asap good parts only no rust or rot
try your local hardware store....the fitting are nothing but brass fitting...not necessarily unique to mopars...
most are 3/8 NPT ...
the one in the manifold is 3/4 pipe .
Just buy a short piece and cut off one if the treaded ends
