Water Pump Heater Hose Fitting?
Heating / Cooling / AC
  1. coalman
    coalman Well-Known Member
    932
    217
    Aug 6, 2015
    Texas
    Local Time:
    6:08 AM
    Is there any type of tool to remove one of these? Thanks
  2. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    8,036
    4039
    Jan 8, 2009
    Danielsville Pa.
    Local Time:
    7:08 AM
    Yes but cheaper sockets usually break. What I found to work years back the best is drill a hole through a cheap deep well socket that fits over the nipple. Install a piece of Hardened Key stock through the hole and tack it in with a light weld. Years ago I cut a slot in a socket with a cut off wheel and set the key stock in the slot. There are several ways.
    My son now has the tools I don't know who he bought them from. I borrow them when he is not looking. It looks exactly like what I told you to make. They are probably Snap-on, Mac, Or KD. They are in a red case. Never looked at the name. Try MSC on line
    • Like Like x 3
    • coalman
      932
      217
      Aug 6, 2015
      Texas
      Local Time:
      6:08 AM
      Thank you, do you happen to know what they are called?
    • jazak5
      jazak5 Well-Known Member
      858
      360
      Aug 6, 2015
      NY
      Local Time:
      7:08 AM
      • Like Like x 1
      • Agree Agree x 1
      • coalman
        932
        217
        Aug 6, 2015
        Texas
        Local Time:
        6:08 AM
      • Demonic
        Demonic Well-Known Member
        1,177
        916
        Mar 21, 2015
        Maryland
        Local Time:
        7:08 AM
        If you have the room - slide an old bolt or round stock down inside that is close to the i.d., and use a small pipe wrench. I have a 12", but the mini 8" Ridge work well also. The bolt keeps it from egging and getting stuck from deforming.
        • Agree Agree x 1
        • coalman
          932
          217
          Aug 6, 2015
          Texas
          Local Time:
          6:08 AM
          Thanks for the tip, I have a Vintage Air System, I tried my smallest pipe wrench, won't get in there without taking the whole compressor mount out.
        • TrailBeast
          TrailBeast AKA Mopars4us on Youtube
          21,285
          8750
          Mar 11, 2011
          Arizona
          Local Time:
          4:08 AM
          @Rainy Day Auto made a socket to remove those.
          In my experience a lot of the time those slots get ripped out trying to get them out that way anyway.
          Heat seems to help.
        • coalman
          932
          217
          Aug 6, 2015
          Texas
          Local Time:
          6:08 AM
          Yes, I was worried about the slots also, I ordered a set I will re post on how things went. I was also thinking of an easy out. Thanks for your response...
          • Like Like x 1
          • Johnny Dart
            Johnny Dart Well-Known Member
            7,779
            2207
            Nov 30, 2006
            So Cal
            Local Time:
            4:08 AM
            Vice grips, then trash them.
            New ones are like $10. give or take.
            To install, get a thick washer. Clamp it into a set of vice grips.
            Insert washer into the groove, and turn.
            PS: If the nipple is locked in and won't budge. Put a torch on the nipple and intake. Get it really hot, and melt wax into the threads. Screws right out.
            • Like Like x 1
            • Agree Agree x 1
            • toolmanmike
              toolmanmike FABO MODERATOR Staff Member FABO Gold Member
              48,617
              33281
              Jan 18, 2006
              Iowa
              Local Time:
              6:08 AM
              The screwdriver type tools are for installation and rarely work for removal. Heat the intake with a torch helps . Some replacements have a hex built in for a wrench.
              • Like Like x 1
              • Agree Agree x 1
              • coalman
                932
                217
                Aug 6, 2015
                Texas
                Local Time:
                6:08 AM
                Sounds good I will give it a try, I have plenty of large washers, been soaking the threads in penetrating oil.. Thanks
              • Oldmanmopar
                8,036
                4039
                Jan 8, 2009
                Danielsville Pa.
                Local Time:
                7:08 AM
                The drag link sockets work if the nipples are new. A tight fitting sleeve such as a deep well socket holds the slots from ripping loose. I never had much luck with the drag link sockets removing old nipples. They work well installing new nipples though. You are correct in using heat. We call our torch set "liquid wrench"
                • Agree Agree x 2
                • Like Like x 1
                • lemondana
                  lemondana BlackDart
                  395
                  198
                  Dec 7, 2007
                  Southeast NE
                  Local Time:
                  5:08 AM
                  I thought I remember someone on here machining some neat sockets with the screwdriver end that fit down in the fitting a little bit. I think he had three different sizes in the sets he sold. Anyone else remember them?
                • famous bob
                  famous bob mopar misfit FABO Gold Member
                  16,268
                  6127
                  Aug 14, 2011
                  okla
                  Local Time:
                  6:08 AM
                  It would be hard to find now a days , but there were plumbing tools made for that exact purpose. I have one for a 1/2'' pipe size somewhere --------------
                • coalman
                  932
                  217
                  Aug 6, 2015
                  Texas
                  Local Time:
                  6:08 AM
                  I am going to work on it today, the biggest problem as I see it is the slots are on top and where it needs to move is at the bottom. If it would have a hex head on the side it would have been out by now... Thanks
                  Well it is out, I took all the A/C mounts off to do it with heat and a small pipe wrench.
                  The npt is 5/8 the same as the hose fitting. Anyone ever seen this? It is out of the water pump. Thanks
                  • Agree Agree x 1
                  • coalman
                    932
                    217
                    Aug 6, 2015
                    Texas
                    Local Time:
                    6:08 AM
                    I am going to convert this to 1" water pump bypass fittings in the intake and water pump anyone have a source for these 360 LA motor? Thanks
