Water Pump Hookups
JChastain13
Member
Dallas
Can someone describe which opening in the 440 water pump housing is the inlet from the heater core and which is the outlet to the heater core, and which is the temperature sensor inlet? You would think it would be an easy thing to find but I'm coming up with nothing on searching the net. 69 barracuda so both hoses are the same size.
For operation, it shouldn't matter since the heater core has no direction. It would only matter if you want to be historically correct.
Install the hoses (both of them) to the heater core. Then, cross them as they run to the water pump. Then hook them to the fittings. If they cross on their route from the heater box to the water pump, you have them hooked up correctly.
What do you mean by "temperature sensor inlet"?
George
A lot will depend on your year and model but assuming it's a late 60's-early 70's setup and you have a water pump housing with 4 holes on top, the hole closest to the water pump is the return hose from the heater core. That also should be the hole nearest the centerline of the engine. The hole closest to the passenger fender (next to the valve cover) is the output to the heater core and would the one you should attach to the water valve if you have one in your system. The holes inbetween the heater inlet and outlet are for sensor, senders, and smog valves. The standard temp gauge sender should go into a small 5th hole pointing to the front of the car. Some of the C-bodies used a different temp sender that went up top in one of the big holes. Just put pipe plugs into the ones you're not using.
