markfh
What's the best way to remove the hose connectors in my water pump?
I have got some STUCK A$$ bolts out using the wax trick and a propane torch. I think you'll like it.I'll have to try that wax trick! I would try PB Blaster too. Definitely gonna need heat for sure.
that solid rod or bolt sounds like a good idea !Use mapp gas in your bernsomatic torch. A bit hotter than propane. Heat, pb blaster and repeat. The coolness of the pb blaster shrinks the metal slightly allowing the oil to penetrate. Also stick a solid rod in the hole before clamping it with a pipe wrench to prevent it getting crushed.
