water pump outlets
Tadams
Tadams
nc
Replaced the water pump today and the outlets for the heater hoses didn't come with the pump. The old ones are not in the best shape. I called the store where I ordered the pump and they don't have a listing for those.
Any thoughts about where I could purchase these
Go to a good hardware store, where they have a large selection of "brass" plumbers fittings, and dig through them, You will probably end up using Little short pipes (I think they are called nipples). Get ones that are a little to long, that screw into the pump, and cut off the threads one end , smooth it with a file, so the hoses slide on nice. Thats what I have done a few times. The brass wont promote disimiler metal corrosion. Hope this helps.
barracudadave67
I found a listing in classic industry catalog. About 30 for two of those.
