this is strange ,the water pump impeller on my reman pump is opposite of the one that was on my engine is that ok? or should i use my old pump? i know it worked ok i'm going to try to post a picture of them on here .
The same question came up a month or so ago, so maybe some "wrong" ones got into the supply chain. Somebody said the "wrong" pump is for Chrysler marine engines (or industrial?). They probably ran the belts differently, which turned the water pump reversed. Both would work, just a little less optimally perhaps.
