mikess68
1972 318. the blow by hose came off and lossed all the antifreeez.
when putting back on, notice that inside the water pump hose housing it appears to have a check valve, or flow restriction type devide. 1/2 the flow seems to be cut off by a washer type device. is this normal or shoule it be removed or what. need some advice before i put it back together............ tks
