Water pump
65MagnumFish
65MagnumFish
Zeeland, MI
I’m getting ready to buy a water pump for my 5.9 magnum. I am planning on installing the eddy airgap intake. Any suggestions on the water pump? The motor is going in a 65’ Barracuda if it matters. This site and its members have been awesome to me so your advice is well taken.
Your going to have to get the proper radiator. I believe the outlets are different from the early A's. 65 has the 22" radiator support, you may be able to make a 26" radiator work but it takes some doing. 65'
I should have mentioned that I don’t have a radiator yet. Is there a pump that is angled differently then others? Also should I go OEM? Thanks
