72Dart360
I recently removed the heater/AC box from under the dash. Where can I get some rubber plugs or something to block off the ports on the waterpump?
GoodysGotaCuda said:Allen here as well.
I like that ram air set up. Do you have any data on increased or decreased performance? The rubber caps are a good tempory fix for the pump nipple. However, I used one for mine & less than 500 miles it is badly weather cracked. I think I'll put a plug in it. A buddy warned me about the rubber caps, but what does he know. LOLGoodysGotaCuda said:Allen here as well. Or the 'help' section at your local parts place will have little nipple caps you hold down with a clamp (check out the heater core, there is a pair of them on there..)
