Weird smell
dropshot1
stoney creek
Just wondering if it is normal when breaking in a new third member to have a weird smell, just running the car up on jack stands at idle for the first time with the new carrier and i smell something almost like burning wood
You did put gear-oil in it right?
Then,Probably your brakes.
If it kindof burn your nose, check your drums for heat.....carefully! , they should remain cold
I would run it with oil in it until I got the smell and then go check where it's getting hot it maybe brakes or it could be a tight pinion or a number of things .
Yeah i put the friction modifier first then the royal purple gear oil until it came out the fill plug, is it possible i put too much grease on the axle bearings, also i did an oil change weeks back when i first put the car up on stands and used the valvoline vr1 with zinc, could it be the smrll from the zinc
My smelliphone couldn't pick it up!:poke::poke: That kind of smell is probably brakes dragging. (and brakes can be a drag)
