You might keep in mind that breaking a **** rear end can ruin the sprag in the automatic, "if that's what you have."
Actually, "in the old days" a friend of mine broke the 10 bolt in his 65 Chevelle, and after we got the axle replaced, we discovered THE MUNCIE 4 SPEED INPUT SHAFT HAD SNAPPED
This is the guy who later was the first owner of my 70 440-6 RR. When I arrived at Navy Electronics "A" school at Treasure Island in the fall of 68, and eventually made my way to the then fantastic amateur radio club, K6NCG,
(Some photos of the club here
K6NCG - Treasure Island Radio Amateur Club 1969-1970
here sits George's 65 Chevelle. "It turns out" that he had bought and junked out a low miles wrecked 67 350, 4 speed Camaro. So now the 350/ 4 speed and Rally wheels were on the Chevelle
"Sometime later" after we had become friends, he was (as usual) building up the muscles in his right (throttle) foot, his left (clutch) foot, and his "shifting arm" ..........getting onto the San Francisco Bay Bridge leaving "the Island" and broke the rear axle going into second gear off the on ramp.
We coasted for awhile, "dived" into a turnout on the bridge just as the rear end locked up. There were 3 or 4 of us in the car, I don't remember. Two of use jacked up the car and got one rear wheel setting on the spare tire. I crawled under and removed the rear cover. The C clips fell out as we tried to gut the thing and get it to turn, and neither of us!!! knew what the C clips were for!!!
So here comes the tow truck, who decides to PUSH US down off the bridge. As we went down the ramp, an horrible rubbing of the tires insued!!!! Of course there ARE NO BRAKES because this is before dual master cylinders!!!
But George is a pretty smart guy, and already had a "line lock" on the car. He pushed the button, and "stabbed" the brakes a couple of times to build a bit of pressure in the fronts..........and we rolled to a gentle stop at the bottom of the bridge!!!
Tow truck went around, hoisted the rear, and towed us all back to the island!!! LMAFAO!!!!
We bought a used 10 bolt at a junk yard, and put the thing in. Started 'er up and IT WENT NOWHERE!!!
NOTICE this photo of a Muncie shaft I found on the www
NOTICE the groove around the shaft splines........I know not what they are for, but that shaft BROKE RIGHT THERE in that groove just as clean as could be, and !!!POOF!!! we have a 'free' alignment tool for putting the clutch in!!!
